How is it possible to add personal notes to an album in order to supply the most of the time missing booklet?
hello @fdoenz,
If you want to add a booklet to an album, pleas add the pdf file in the album folder and you should see a book icon in the album after the sync of Studio.
Many many thanks for your replay and the clafication, but I use only streaming for my playlists and it seems it is not possible to add notes in this case!?
If I use only streaming it is for practical reasons, and do not want to mess with local files as with my CD…
