How to chose muitlchannel or stereo "layer"?
Hi, as told before Audirvana only shows the multichannel songs from the SACD ISO. My system can reproduce both, but how can I chose?
In other softwares, you can see all songs (repeated) stereo first, and then multichannel, that is also a little annoying, but at least, you can chose what “layer” you want to listen to.
Thanks!
Hello @blackmore1514k, you should be able to switch between multichannel and stereo in your audio output setting of your DAC (mine is only stereo)
Hello.
My DAC (Oppo 205) supports SACD multichannel, but I’m not able to switch audio in an ISO file. Only “stereo” appears and it’s not switchable.
My Audirvana version (on Mac) is the last one (3.5.38).
I look forward to hearing from you.
Have a nice evening.
Gianluca
Hello @gsagen,
Hello Damien and thanks for the answer.
I copy here the last two debug infos, first with cable USB connection, second with UPnP connection by home network.
Have a nice day
Gianluca
macOS 10.15.5 with 16384MB RAM
Registered to Gianluca Saggini
iZotope SRC not in use iZotope SRC filter parameters
Steepness = 150
Filter max length = 1000000
Cut-Off (x Nyquist) = 100%
Anti-aliasing = 200
Phase = 73%
Sync list: 7 folders
AUTO: /Users/Gianluca/Downloads/MUSICA
AUTO: /Volumes/ARCHIVIO CD/SACD
Manual: (OFFLINE) /Volumes/SSD 500GB/BRAHMS RATTLE/WAV
Manual: (OFFLINE) /Volumes/SSD 500GB/CONCERTANTE RIETI
Manual: (OFFLINE) /Volumes/SSD 500GB/DVORAK - ARENSKY LP/9624
Manual: (OFFLINE) /Volumes/SSD 500GB/ZUPERMAN/19224 Tracks
Manual: (OFFLINE) /Volumes/SSD 500GB/ZUPERMAN/9624 Tracks
Library database path: /Users/Gianluca/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Login failed
OPPO UDP-205
Model UID:OPPO OPPO UDP-205
UID:uuid:71cfb39c-1dd2-11b2-a99e-ae1686b69932
Active Sample Rate: 48kHz
ID 0x3c Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:57 UID:AppleHDAEngineOutput:1F,3,0,1,1:0
3 available sample rates up to 96000Hz
Stream ID 0x3d 2 channels starting at 1
3 virtual formats:
3 physical formats
Device #0: ID 0x3c Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:57 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x2a Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0
Second Debug info
Steepness = 150
Anti-aliasing = 200
Phase = 73%
Preferred device: OPPO UDP-205 Model UID:OPPO OPPO UDP-205 UID:uuid:71cfb39c-1dd2-11b2-a99e-ae1686b69932
UPnP device at http://192.168.1.40:49152/dmr_oppo.xml
ID 0x0 OPPO UDP-205 Manufacturer:OPPO
Volume control: No
DSD capability: Raw DSD (MSB)
http-get:*:audio/L16:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320
http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320
http-get::audio/L16:
http-get::audio/L8:
http-get::audio/mp1:
http-get::audio/mp2:
http-get::audio/mpeg:
http-get::audio/basic:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/x-matroska:
http-get::audio/mid:
http-get::audio/x-ms-wax:
http-get::audio/wav:
http-get::audio/x-ms-wma:
http-get::audio/vnd.rn-realaudio:
http-get::audio/x-wav:
http-get::audio/x-flac:
http-get::audio/mp4:
http-get::audio/x-m4a:
http-get::audio/x-ms-wmv:
http-get::audio/x-ogg:
http-get::audio/dff:
http-get::audio/dsd:
http-get::audio/dsf:
http-get::audio/ogg:
http-get::application/ogg:
http-get::audio/midi:
http-get::audio/x-aac:
http-get::audio/aac:
http-get::audio/x-ac3:
http-get::audio/x-atrac3:
http-get::audio/x-dts:
http-get::audio/x-pn-realaudio:
http-get::audio/x-quicktime:
http-get::audio/dolby:
http-get::audio/adts:
http-get::audio/3gpp:
http-get::audio/sonyoma:
http-get::audio/mp3:
http-get::audio/mpeg3:
http-get::audio/wma:
http-get::audio/flac:
http-get::audio/audible:http-get::video/vnd.dlna.mpeg-tts:
http-get::video/mp4:
http-get::video/3gpp:
http-get::video/mp2p:
http-get::video/mpeg2:
http-get::video/quicktime:
http-get::video/x-dv:
http-get::video/x-motion-jpeg:
http-get::video/x-nerodigital-ps:
http-get::video/mp1s:
http-get::video/tts:
http-get::video/x-msvideo:
http-get::video/divx:
http-get::video/xiid:
http-get::video/asf:
http-get::video/wmv:
http-get::video/x-matroska:
http-get::video/rtml:
http-get::video/x-ms-wmv:
http-get::video/x-ms-wmx:
http-get::video/x-ms-wm:
http-get::video/x-ms-asf:
http-get::video/x-ms-wvx:
http-get::video/x-ms-dvr:
http-get::video/avi:
http-get::video/mpeg:
http-get::video/vnd.rn-realvideo:
http-get:*:video/x-pn-realmedia:http-get::application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_JP_T
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/mpeg”:DLNA.ORG_PN=DTCP_MPEG_PS_NTSC
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/mpeg”:DLNA.ORG_PN=DTCP_MPEG_PS_PAL
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_NA
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_NA_T
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/mpeg”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_NA_ISO
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_HD_NA
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_HD_NA_T
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/mpeg”:DLNA.ORG_PN=DTCP_MPEG_TS_HD_NA_ISO
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_KO
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_KO_T
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/mpeg”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_KO_ISO
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_HD_KO
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_HD_KO_T
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/mpeg”:DLNA.ORG_PN=DTCP_MPEG_TS_HD_KO_ISO
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU_T
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/mpeg”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU_ISO
http-get::image/vnd.ms-photo:
http-get::image/gif:
http-get::image/x-ycbcr-yuv420:
http-get::image/jpeg:
http-get::image/png:
http-get::image/mpo:
http-get::image/x-icon:
http-get::image/x-quicktime:
http-get::image/jpe:
DLNA 1.5: Yes
Gapless playback: No
Missing events workaround: No
Can play native DSD: Yes
34 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 22579.2kHz
0 physical formats
NrTracks: 0
MediaDuration: 00:00:00
CurrentURI: null
CurrentURIMetadata: null
nextURI: NOT_IMPLEMENTED
PlayMedium: NETWORK
RecordMedium: UNKNOWN
<?xml version="1.0"?>
1
0
SetAVTransportURI
InstanceID
in
A_ARG_TYPE_InstanceID
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
AVTransportURIMetaData
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
NextAVTransportURIMetaData
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetTransportInfo
InstanceID
in
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
Stop
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Pause
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
Next
InstanceID
in
Previous
InstanceID
in
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
GetCurrentTransportActions
InstanceID
in
Actions
out
TransportStatus
string
OK
ERROR_OCCURRED
NextAVTransportURI
string
string
string
i4
ui4
string
string
UNKNOWN
DV
MINI-DV
VHS
W-VHS
S-VHS
D-VHS
VHSC
VIDEO8
HI8
CD-ROM
CD-DA
CD-R
CD-RW
VIDEO-CD
SACD
MD-AUDIO
MD-PICTURE
DVD-ROM
DVD-VIDEO
DVD-R
DVD+RW
DVD-RW
DVD-RAM
DVD-AUDIO
DAT
LD
HDD
MICRO-MV
NONE
NOT_IMPLEMENTED
string
string
CurrentPlayMode
string
NORMAL
REPEAT_TRACK
REPEAT_ALL
REPEAT_ALL
TransportPlaySpeed
string
1
string
string
CurrentTrack
ui4
0
4294967295
1
CurrentTrackURI
string
NumberOfTracks
ui4
0
4294967295
AVTransportURI
string
i4
string
0:EP
1:LP
2:SP
0:BASIC
1:MEDIUM
2:HIGH
NOT_IMPLEMENTED
string
string
A_ARG_TYPE_SeekMode
string
TRACK_NR
REL_TIME
string
RecordStorageMedium
string
UNKNOWN
DV
MINI-DV
VHS
W-VHS
S-VHS
D-VHS
VHSC
VIDEO8
HI8
CD-ROM
CD-DA
CD-R
CD-RW
VIDEO-CD
SACD
MD-AUDIO
MD-PICTURE
DVD-ROM
DVD-VIDEO
DVD-R
DVD+RW
DVD-RW
DVD-RAM
DVD-AUDIO
DAT
LD
HDD
MICRO-MV
NONE
NOT_IMPLEMENTED
string
WRITABLE
PROTECTED
NOT_WRITABLE
UNKNOWN
NOT_IMPLEMENTED
LastChange
string
string
TransportState
string
STOPPED
PAUSED_PLAYBACK
PAUSED_RECORDING
PLAYING
RECORDING
TRANSITIONING
NO_MEDIA_PRESENT
string
1
0
dlna:X_DLNADOCDMR-1.50</dlna:X_DLNADOC>
OPPO UDP-205
OPPO
qq:X_QPlay_SoftwareCapabilityQPlay:2.1</qq:X_QPlay_SoftwareCapability>
http://www.oppodigital.com/
OPPO Media Renderer
OPPO UDP-205
20X
image/png
48
48
24
/icon/DMR-small.png
image/png
120
120
24
/icon/DMR-large.png
image/jpeg
48
48
24
/icon/DMR-small.jpg
image/jpeg
120
120
24
/icon/DMR-large.jpg
/dmr_oppo_rcs.xml
control/RenderingControl
event/RenderingControl
/dmr_oppo_cms.xml
control/ConnectionManager
event/ConnectionManager
/dmr_oppo_avts.xml
control/AVTransport
event/AVTransport
urn:schemas-tencent-com:service:QPlay:1
urn:tencent-com:serviceId:QPlay
/control/Queue
/event/Queue
/dmr_oppo_queue.xml
UPnP devices found : 2
Device #0: ID 0x0 Living UID: uuid:9ab0c000-f668-11de-9976-ac44f24f6ecd Location: http://192.168.1.176:49154/MediaRenderer/desc.xml
Device #1: ID 0x0 OPPO UDP-205 UID: uuid:71cfb39c-1dd2-11b2-a99e-ae1686b69932 Location: http://192.168.1.40:49152/dmr_oppo.xml
Does your OPPO is up to date? It doesn’t give the proper information for channels in Audirvana
On USB:
On UPNP:
My Oppo has the last firmware available…
Have you tried to connect it via HDMI or SPDIF? It seems to be the only way to get multichannel with this this DAC as i can read it on the user manual.
That is correct. USB-B port DAC is only STEREO. HDMI is both stereo and multichannel.
I think Oppo should accept and decode DSD signal (stereo and MCH) via USB. If not, maybe could be an Audirvana problem.
When I play SACD discs I have no problem to switch from stereo to MCH track. It should happen with Audirvana player too.
I don’t know if DSD signal goes out from Mac HDMI port (MAC doesn’t have a SPDF port), but I think no.
HDMI is just a port like USB, it transmit information from one device to another so yes, you will be able to send DSD through the HDMI port of your Mac.
Hello Damien.
I just tried to connect both Oppo 205 or Emotiva XMC-2 via HDMI. In both cases it works only if Audirvana converts the DSD signal to PCM. System detects 7.1Ch and you can switch, but Oppo or Emotiva doesn’t do the conversion. Oppo decodes native DSD signal, so it should be the best way for audio quality. Sw conversion never will be better.
I don’t know why Oppo doesn’t recognize MCH signal over USB or network connection.
Could you try to find more infos about?
Thanks a lot.
Have a nice day.
It’s a manufacturing choice made by Oppo, the best way would be to ask them, it think they preferred to stick to HDMI for DSD and the speed it of this connectivity or maybe they have more knowledge about it.
I have same issue with Oppo 105D. Audirvana only recognizes it as a Stereo device. With Foobar I can play multichannel files via UPNP. Audirvana only does Stereo.
If you’re using the Mac version of Audirvana, and you’re connected to a DAC that will play multichannel, in order to get a multichannel option in Audirvana’s configuration (Output Device set to 7.1) you need to do this.
  1. Close your session of Audirvana.
  2. Open Audio Midi Setup on your Mac.
  3. Highlight your DAC (or the Oppo in your case)
  4. To the right side of that window, see “Format:” and choose 8ch 32 bit integer…etc…(bit rate doesn’t matter. You just want 8ch selected).
  5. Reopen Audirvana and then you’ll see 7.1 as available.
