Here you go:
The old drive path is /Volumes/MASTER2/Music/Music_downloads/
and the new one is /Volumes/Music_Server/
Audirvana Origin 2.5.2 (20502)
macOS 12.7.1 with 32GB physical RAM
Connected account of : *******************
Manual: /Volumes/Music_Server/
Library database path: /Users/dimsal/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 54769
Max. memory for audio buffers: 8494MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Cayin Cayin RU6 Playback
Model UID:Cayin RU6:2D87:C001
UID:AppleUSBAudioEngine:Cayin:Cayin RU6:Cayin RU6:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 6 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Hog Mode is on
Selected device:Cayin RU6 Playback
Manufacturer: Cayin
Model name: Cayin RU6 Playback
Model UID: Cayin RU6:2D87:C001
UID: AppleUSBAudioEngine:Cayin:Cayin RU6:Cayin RU6:1
USB Vendor ID: 0x2d87
USB Product ID: 0xc001
ID 0x46
Stream ID 0x47 2 channels starting at 1
32 virtual formats:
48 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 352.8kHz
Local devices found : 4
Device #0: ID 0x46 Cayin RU6 Playback
Manufacturer: Cayin
Device #1: ID 0x4d Cayin RU7 Playback
Manufacturer: Cayin
Model UID: Cayin RU7:2D87:C002
UID: AppleUSBAudioEngine:Cayin:Cayin RU7:Cayin RU7:1
USB Product ID: 0xc002
Model name: Cayin RU7 Playback
Device #2: ID 0x3a External Headphones
Model UID: Codec Output
UID: BuiltInHeadphoneOutputDevice
Model name: Apple Inc. External Headphones
Device #3: ID 0x2d MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
