We found a way for doing it
It needs to be better implemented in the app but it’s a first step
Unfortunately it seems this issue doesn’t show up in the logs… I don’t know about you patifr, but it doesn’t work for me.
Since this is a character issue, I don’t know if it is any interesting, but my internal drive and external drive both run APFS.
Hi Yohmi,
On my side, I tested the new version with the logging capability. Maybe I was lucky but I did not encounter any error so far that I could track with the logfile.
To make sure that if an error occurs I would have been able to track it, I decided not to apply my usual strategy with the ‘rsync’ command. So, I copied directly the audio files to the folder declared in Audirvana and nothing strange happen.
Maybe this problem has also something to do with the Mac OS version: on my side I’m still with Catalina, applying this wise principle “if it ain’t broken, don’t try to fix it”.
Maybe you could send the original audio files to Antoine (I would be by the way also interested to test it on my own platform) to see if he can reproduce the issue.
Having the same issue with Origin.
Oddly, I found some folder/file names with accents or other non-ASCII characters produce the “Unable to open an audio file for playback” message while other files with similar characters play just fine.
This is on two different Macs, both running Ventura 13.3.1. Removing the accented character in the folder name resulted in the album playing.
Hi guys,
Thank you for your feedback on this. We are looking for a way to reproduce the issue and fix it. I hope I will be able to try reproducing it next week.
Hi there,
Hi Antoine,
I found something interesting I guess on my side. As we have now a Mac version of Audirvana with loggging capabilities, I decided to bypass my specific procedure that converts files in the UTF-8 Mac format.
So, I copied and pasted a set of four albums coming from a Linux server (My guess) to a Synology NAS, and here are my findings:
So, in a nutshell, problem is not AFP or SMB, problem seems to be linked to the way accented chars are built.
I did not come to a clear conclusion so far and I’m still a little lost when contemplating the facts I collected so far.
Just my two cents.
In addition to this, I found that:
Confused I am, to say the least…
Ok, thank @patifr for your sharing your findings.
This is something I will need to figure out next week
I’m happy to report that all my issues with playing tracks which had umlauts, accented characters etc. (anywhere in the metadata) have vanished after the recent macOS update to version 13.4.
Good to read it!
So, it was not a problem coming from AS but something introduced in a first version of Ventura.
Thing is that, at least on my side, I have sometimes the same problem on older MAC OS versions.
What I understand is that your problem appears with files stored on disks directly under the control of a MAC, and formatted accordingly.
Mine is apparently occuring when I mount disk volumes using AFP or SMB with some files inside that comes from an external platform (Most probably Unix or Linux but TBC) with malformed accented chars.
That explains that after a conversion to the MAC format (Or a simple copy to a pure MAC volume apparently), the issue disappears.
13.4 update fixed the issue for Origin as well.
Ventura 13.4 also solved the issue in my case
13.4 didn’t solved the issue, they repaired their fucked up
Agreed! It’s a pitty to see Apple working more and more like MS… and so many others.
