How to open SACD iso? Audirvana 3.5.41 macos 10.12.6
Hello @Aumnavigator,
You need to put the file in a synced folder with Audirvana, if you donβt have a synced folder, you can add one using the + or Add a folder button in the Library section of Audirvana settings.
Thanks a lot for you
