Hello,
I just subcribed to Tidal HiFi/Master, as I hoped to play Dolby Atmos tracks on my Dolby Atmos enabled Denon Receiver.
So I thought, I’d install the Tidal app on my ChromeCast with Google TV, connect it via HDMI to my Denon and straight to music heaven…
Well, when I start a Dolby Atmos Track… nothing happens, stops immediately and no sound..
So apparently, the Tidal App on Google TV does not decapsulate the MQA stream and Denon doesn’t support MQA yet… end of story and end of dream. ![]()
Then saw a post on an audioforum, that with Audirvana, you could connect to the Tidal service and via UPnP I would be able to stream the master files to my Denon, as Audirvana can decapsulate the MQA stream and send it pure to another device. So my hopes went up again…
So I installed Audirvana on my Mac Book and was able to stream music (in higher resolution the CD quality, some in 24/192)) to the Denon, but only Stereo… Dolby Atmos tracks only streamed in stereo.
Then I got the idea to connect my Macbook to the Denon via HDMI cable.
Audirvana saw then my Denon as 7.1 multichannel source…
So played a Dolby Track and it streamed as multi channel 7.1 to the Denon, who saw it coming in as PMC multichannel stream and it showed in the Denon App also as multi channel out put…
But yet, music only comes from the two main front speakers… in stereo…
So up till now, I have not found a way to play Dolby Atmos Tidal tracks on my Denon Receiver
(Netflix Dolby Atmos movies on my Google TV play in wonder 3D surround, so technically all is fine with the system).
Hope some one can help me realize this ? Or does anybody have another idea with out investing in another expensive extern DAC or Roon ?
Thanks and kind regards,
Luc
