Hello,
I used to remote Audirvana 3.5.44 and previous with Audirvana Remote on IOS.
Audirvana remote does not find Audirvana Studio Library.
How to do ?
There is, as yet, no remote for Studio, It is promised soon.
So, I’ve just read it in the FAQ.
Thanks for your answer.
I don’t know about you, but I think they should not start the 30 day trial clock until the remote is available and working. Personally not a great start to the release if you ask me.
I fully agree with this idea. It’s frustrating to control a headless MacMini with my laptop.
Have you setup Screen Sharing on the Mac Mini?
I have found it to be the most convenient way to control a headless Mac Mini, both visually and functionally.
I only use a VNC application when controlling it from a tablet. This tends to be less satisfying visually, and at times awkward for typing.
You can do a screen sharing with an other Mac if you have one available. I never used the remote as I don’t like it and always did that way.
Try Splashtop!
Hello. What’s the difference between version 1.5 and version 3.5 for Windows 10? In the first one, the pilot sees the computer but shows UnknownError all the time. Of course, I performed all the recommended operations with the network settings. Version 3.5 will not start without a license key. Greetings!
