How do you start A for Windows? I have no start menu entry and have to use the download link to launch every time.
Hello @Beatles,
You mean you don’t see Audirvana in the list of software in the Start menu on the left of Start?
I use a replacement start menu but it’s not there and there’s no executable file anywhere.
What are you using as replacement of the startup menu?
Start is Back…
Audirvana use the UWP app system, which means the exe file is secured and is not accessible by the user, I think you should ask Start is Back developer if he support it as if you download any software from the Microsoft Store, you won’t be able to see it through Start is Back.
