That depends on the driver, but first thing to check is if you can find it in add/remove programs in control panel.
Not there I was looking for is not there. I use Windows 10 PRO
Kernel streaming skips all software before your player except for the tiniest part of your OS. ASIO skips the kernel, and outputs the least muddied signal to your output port.
