I actually have 2 problems. First, I get an “errorloggkng into HRA-Streaming” message every time I open the software. I have attached the de-bug info. Also I cannot access my local library from a USB attached hard drive.Thanks for any help.
macOS 12.4.0 with 16384MB RAM
Registered to Richard Garrad
AU plugin #0: None
AU plugin #1: Effect - Sonimus SonEQ ()
AU plugin #2: None
AU plugin #3: None
AUTO: /Volumes/My Book2 for Mac/iTunes/Music
iTunes/Music library synchronization: last synchronized on Wed Jun 15 15:38:42 2022
Library database path: /Users/richgarrad/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
HRA-Streaming: Login failed
TIDAL: Connected as PREMIUM
AudioQuest DragonFly Red v1.0
Model UID:AudioQuest DragonFly Red v1.0:21B4:0082
UID:AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Red v1.0:AQDFRD0100133275:1
ID 0x2a AudioQuest DragonFly Red v1.0 Manufacturer:AudioQuest
Model UID:AudioQuest DragonFly Red v1.0:21B4:0082 UID:AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Red v1.0:AQDFRD0100133275:1
Stream ID 0x2b 2 channels starting at 1
8 virtual formats:
8 physical formats
Local devices found : 3
Device #0: ID 0x3f DELL S2319NX Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:10001:0:{AC10-D0DD-30445A42}
Device #1: ID 0x35 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:15 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #2: ID 0x2a AudioQuest DragonFly Red v1.0 Manufacturer: AudioQuest Model UID: AudioQuest DragonFly Red v1.0:21B4:0082 UID: AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Red v1.0:AQDFRD0100133275:1
UPnP devices found : 1
Device #0: ID 0x0 Rich’s Hegel UID: uuid:22a4e348-1dd2-11b2-8150-215f23f74968 Location: http://192.168.1.6:38400/description.xml
