Hi, Running Audirvana 3.5.9 on a Mac Mini connected by USB to a Chord Qutest DAC. With Tidal or plain old CDs as flac files it sounds amazing. However, when streaming from Hiresaudio (HRA) it sounds even better to me BUT reliably & repeatedly crashes Audirvana after 4 to 5 minutes of playback. Any solutions?
A little more info re the issue:
The crashes only seem to occur when playing the track from the HRA-streaming list!
If the album in its entirety is listed on screen then all tracks play just fine. Also, seems OK from the HRA-streaming list on 44KHz sample rate tracks but on 192KHz crashes as outlined.
Can you check if you still have this issue with 3.5.11 ?
