The Library function was working fine until just last week – i think it was after the last update. The Library is now entirely unaccessible – there is some bug that prevents it from being displayed. The window is just blank. Has anyone encountered this?
I can search in the search bar, and that brings up specific artists/albums – but i cannot view the entire library.
Display of my playlists is working fine. (These are imported from iTunes)
i have the latest version of Audirvana. 3.5.25 for MacOS
Running Mac 10.12, Sierra.
there used to be a link on the Audirvana web site to email support with bug reports. I don’t see this anymore. Can anyone tell me if there is a place to report bugs, or does one do it now in this community forum?
thx for help. debug info below:
Debug Info:
Audirvana Mac Version 3.5.25 (3555)
macOS 10.12.6 with 8192MB RAM
Replay Gain: by album
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Wed Jul 17 15:12:50 2019
Library database path: /Users/Gene/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
AudioQuest DragonFly Red v1.0
Model UID:AudioQuest DragonFly Red v1.0:21B4:0082
UID:AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Red v1.0:AQDFRD0100132968:1
ID 0x2e Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:101 UID:AppleHDAEngineOutput:1F,3,0,1,1:0
2 available sample rates up to 48000Hz
Stream ID 0x2f 2 channels starting at 1
2 virtual formats:
2 physical formats
Device #0: ID 0x2e Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:101 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
