Hi everyone
I’m trying to point Audirvana to HQPlayer but for some reason even though the UPnP is enabled, Audirvana will not detect any devices
Firewall is off
Hi everyone
Firewall is off
Just to clarify … are you running HQPlayer Embedded?
Are Audirvana pc and HQPe pc both on the same subnet?
If Audirvana is running on Windows check the Windows Network type: it must be Private and not Public
