Hi!
I tried to Audirvana yesterday and found out a lot of things changed from last access.
Anyway, I have purchased Dragonfly Cobalt and tried to play with Tidal.
It’s not working with my MacBook Air (M2) and showed ‘integer mode’ problem.
When I disconnect Dragonfly Dac, Tidal plays with MacBook Air internal speakers.
and with Dragonfly inserted, turned off ‘integer mode’, there’s no sound.
Please show me the way to solve the problem.
Here’s the Debug info.
macOS 13.0.1 with 16384MB RAM
Registered to Seunghoon Yoo
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Mon Dec 26 00:20:43 2022
Library database path: /Users/seunghoonyoo/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
CoreAudio audio path, buffer I/O frame size: 4096
Integer mode: Disabled
AudioQuest DragonFly Cobalt v1.0
Model UID:AudioQuest DragonFly Cobalt v1.0:21B4:0085
UID:AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Cobalt v1.0:AQDFCB0100124788:1
Hog Mode is on
ID 0x43 MacBook Air 스피커 Manufacturer:Apple Inc.
Model UID:Speaker UID:BuiltInSpeakerDevice
Stream ID 0x44 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x43 MacBook Air 스피커 Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
UPnP devices found : 2
Device #0: ID 0x0 DP-UB9000 UID: uuid:4D454930-0100-1000-8000-FFFFFFFFFFFF Location: http://192.168.1.42:60606/FFFFFFFFFFFF/Server0/ddd
Device #1: ID 0x0 Yellow Room UID: uuid:5f9ec1b3-ed59-1900-4530-ec66d10516c0 Location: http://192.168.0.61:8080/description.xml
