SACD standard only contains these charsets, So i can’t add Unicode/UTF8, other software read iso may error.
SACD standard is publish before 2000.
Hi,
I’m using Catalina on my old MacBook Pro (Mid 2012) and I try to use SACD ISO Tag Editor V 2.1 (1)
I have no problem to open the software, but when I try to open an ISO file, I alway get the message “…could not be opened”.
Someone can help me?
Hi Thomas,
Many thanks for the great tool. It wokrs very well for Audirvana. Just for your information, the tagged album information cannnot be displayed when using foobar2000 on Windows which runs in a virtual machine on macOS, i.e. it is just empty for foobar2000.
It would be cool if one can import the album information from a xml file, in addition to the MuscBrainz. I used foobar2000 to tag the album information, which saves the information in separtely in a xml file. Would be nice if I can upload this into the tool.
By the way, I belive the best solution would be that Audirvava supports the external tagging informaiton like foobar2000 does in the xml file.
Best regards
