SACD ISO’s tags are often incorrect or missing. I can’t find a tool to edit tags, so I spent my spare time making this tool, hoping it will help you.If you feel good, you can donate it, Thank you. If you have any problems, send them to my e-mail: [email protected]
V1.4.2 add MusicBrainZ to search tags
V1.4.3 fix tracks count <=3, lost last track info.
V1.4.4 add Year, and charset add Chinese info.
V1.5.0 change UI, add TouchBar, can Paste Tracks info from web, fix some bugs.
V1.5.1 fix Charset changed not save, Chinese(GB2312) is ok now.
V2.0 add Mulit-ISO open, open a iso will in a new tab.
V2.1 add SACD ISO Preview / QuickLook, need run new version once.
V2.3 add track’s Genre editor.
My macOS 11.4, and my SACD ISO Tag Editor version is 1.4.3, open the ISO file and modify the meta data for the ISO such as artist, title, etc., then save the ISO, but the meta data can’t save to ISO, when re-open the ISO, modification information is roll back.
Hi @Thomas_Hou ,
Your initiative is very nice. It’s the first that I see a tagger for ISO SACD.
I tried to tag with the last version 1.4.3, and unfortunately, it doesn’t for me. I’m using an Intel MBP on macOS 11.4.
Thank you @Thomas_Hou for the tip.
It works the way you say.
Maybe I did not understand how to use the app, but I was only able to change the name of the “Album Artist” and the name of the “Album”, as you can see in the screenshot.
I changed “Angela Hewitt” to “Hewitt, Angela” and changed the name of the album by adding “[SACD]” in the end.
I did not find a way to change the name of the composer of all the tracks, unless I change them one by one.
I was also unable to change the “Genre”. I wanted to input “Piano”, but as this is not one of the presets, it was impossible to input it.
If I can make you a suggestion, it will be very useful for this app to be able to change the tag of “Artist”. It’s impossible to display and to change this tag. Such feauture will be useful for compilations, for instance, or for classical music and jazz where there are different collaborators at each track.
@Thomas_Hou This little utility is incredible! Thank you.
It made me decide to revert back to a full ISO-based archive and skip DSF files altogether. I can’t believe how fast it is as well.
Small request - any chance you can add support for ratings into the tool (I’m not even sure if that’s supported as metadata).
It’s not possible for me to give star ratings inside Audirvana if I am using ISO files since it cannot “burn” the rating into the file itself, so I’m wondering if that can be added as extended metadata somehow.
I thank you so much for your piece of software that make wonders. I hope you will polish it some more from suggestions from others from this comunity but please keep it as simple as you can, and keep a good work.
I wish you all the best for a New Year 2022.
