Hi, Ibasso DC02 dac that can handle DSD 256 DSD, but it is not fully supported in Audirvana.
Adaptateur Amplificateur Casque DAC 2x CS43131 32bit 384kHz DSD256
https://www.audiophonics.fr/fr/amplificateur-casque-mobile/ibasso-dc03-adaptateur-amplificateur-casque-dac-usb-c-hi-res-2x-cs43131-32bit-384khz-dsd256-p-14776.html
Audirvana Mac Version 1.2.0 (10020)
macOS 11.3.1 with 16384MB RAM
Connected account: vicento@mac.com (Stéphane Vicent)
r8brain to DSD128 with filter type B 7th order
Phase minimum phase
Sync list: 2 folders
AUTO: /Volumes/MUSIQUE/Music
AUTO: /Users/stephane/Music/Qobuz
iTunes/Music library synchronization: last synchronized on Sat May 15 23:49:02 2021
Library database path: /Users/stephane/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49498
Max. memory for audio buffers: 3956MB
IBASSO IBASSO-DC-SERIES
Model UID:iBasso-DC-Series:262A:9302
UID:AppleUSBAudioEngine:ibasso:iBasso-DC-Series:2200000:2
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 6 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Hog Mode is on
Sample rate switching latency: 0.5s
ID 0x53 iBasso-DC-Series
Manufacturer: ibasso
Model Name: ibasso iBasso-DC-Series
Model UID: iBasso-DC-Series:262A:9302
UID: AppleUSBAudioEngine:ibasso:iBasso-DC-Series:2200000:2
Stream ID 0x54 2 channels starting at 1
32 virtual formats:
48 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 352.8kHz
Local devices found : 5
Device #0: ID 0x44 U28E590 Manufacturer: SAM Model UID: 4C2D4C0C-0000-0000-0C1E-0103803D2378 UID: 4C2D4C0C-0000-0000-0C1E-0103803D2378 Model Name: SAM U28E590
Device #1: ID 0x53 iBasso-DC-Series Manufacturer: ibasso Model UID: iBasso-DC-Series:262A:9302 UID: AppleUSBAudioEngine:ibasso:iBasso-DC-Series:2200000:2 Model Name: ibasso iBasso-DC-Series
Device #2: ID 0x3e Haut-parleurs Mac mini Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Haut-parleurs Mac mini
Device #3: ID 0x30 Reincubate Manufacturer: Reincubate Model UID: CamoAudioDevice_ModelUID UID: CamoAudioDevice_UID Model Name: Reincubate
Device #4: ID 0x39 EpocCam Microphone Manufacturer: Kinoni Oy Model UID: VirtualMicInputOutput:01 UID: VirtualMicInputOutput:01 Model Name: Kinoni Oy EpocCam Microphone
UPnP devices found : 1
Device #0: ID 0x0 Freebox Player UID: uuid:4c3fb2ed-d64a-3e6e-e8ec-acbe7efddfc4 Location: http://192.168.1.17:54243/device.xml
