Hello all
I’m new to audirvana.
I installed the App on my Mackbook Pro and configured Tidal as my streaming app on nirvana.
I’m confused as i can’t retrieve or see my own playlists that a created on Tidal. All my pusic is there, so please help to solve this issue, because it’s the only reason why i’m purchasing audirvana, i have no offline music.
Hi @Kamal_Bentoufa,
You have two ways to get your Tidal playlists:
- is by going on the My Playlists panel:
- by using the playlists editor:
Thank you so much. It works
I continue my exploration and tests
Best regards,
Kamal
