Hi,
Since new Studio release having a lot of trouble with icons not being shown. (never had this on 3.5)
Many of the tidal & radio screen are blank. (see samples)
The artist screen only appears once, if you exit it, the second time it’s blank.
Here is the debug info:
Audirvana Mac Version 1.0.0 (10000)
macOS 10.14.6 with 4096MB RAM
Bandwidth at 0dB = 99.5%
Phase = 66%
AUTO: /Users/guidojongbeis/Documents/Audirvana
Library database path: /Users/guidojongbeis/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on fe80::8dd:76fb:d415:22b0%en1 on port 50451
Max. memory for audio buffers: 1024MB
APPLE INC. BUILT-IN OUTPUT
Model UID:AppleHDA:88
UID:AppleHDAEngineOutput:1B,0,1,2:0
ID 0x43 Built-in Output
Model Name: Apple Inc. Built-in Output
Model UID: AppleHDA:88
Stream ID 0x44 2 channels starting at 1
4 virtual formats:
16 physical formats
Local devices found : 3
Device #0: ID 0x43 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x54 DisplayPort Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutputDP:1B,3,1,0:0:{AC10-A0A2-32374A4C} Model Name: Apple Inc. DisplayPort
Device #2: ID 0x27 Hue Sync Manufacturer: Philips Lighting B.V. Model UID: com_lighting_HueSyncEngine:0 UID: com_lighting_HueSyncEngine:0 Model Name: Philips Lighting B.V. Hue Sync
UPnP devices found : 12
Device #0: ID 0x0 Denon AVC-X6700H UID: uuid:3316caa1-9db9-1108-0080-00067839c782 Location: http://192.168.1.250:60006/upnp/desc/aios_device/aios_device.xml
Device #1: ID 0x0 Denon Home 150 UID: uuid:caddbd1a-040c-1716-0080-00a96f02fe1d Location: http://192.168.1.133:60006/upnp/desc/aios_device/aios_device.xml
Device #2: ID 0x0 210-0024C50023bc UID: uuid:F9420EBC-191F-1241-8925-0024C50023BC Location: http://192.168.1.239:38400/description.xml
Device #3: ID 0x0 Slaapkamer UID: uuid:0be65d64-8d1c-45e1-86b2-f19537049815 Location: http://192.168.1.130:42532/0be65d64-8d1c-45e1-86b2-f19537049815.xml
Device #4: ID 0x0 Denon Home 150 UID: uuid:6d44696d-88e0-1af0-0080-00a96f02fe1d Location: http://192.168.1.133:60006/upnp/desc/aios_device/aios_device.xml
Device #5: ID 0x0 Denon Home 150 UID: uuid:66b75c7d-6906-10e9-0080-00a96f02fe1d Location: http://192.168.1.133:60006/upnp/desc/aios_device/aios_device.xml
Device #6: ID 0x0 Denon Home 150 UID: uuid:65beedf2-ff88-93e6-dccd-b6012b1600ea Location: http://192.168.1.133:60006/upnp/desc/aios_device/aios_device.xml
Device #7: ID 0x0 Denon Home 150 UID: uuid:259a2824-54e3-aeb0-7b93-9b6b8dcf931e Location: http://192.168.1.133:60006/upnp/desc/aios_device/aios_device.xml
Device #8: ID 0x0 Denon AVC-X6700H UID: uuid:6af1b12f-c7b3-1000-0080-00067839c782 Location: http://192.168.1.250:60006/upnp/desc/aios_device/aios_device.xml
Device #9: ID 0x0 Denon AVC-X6700H UID: uuid:c9d88597-6ccf-19bf-0080-00067839c782 Location: http://192.168.1.250:60006/upnp/desc/aios_device/aios_device.xml
Device #10: ID 0x0 Denon AVC-X6700H UID: uuid:bf9f9e10-2b09-fa0e-c45e-54d5663b4c82 Location: http://192.168.1.250:60006/upnp/desc/aios_device/aios_device.xml
Device #11: ID 0x0 Denon AVC-X6700H UID: uuid:1592ede6-9afb-1a76-ad6f-d59ea6cb3cb3 Location: http://192.168.1.250:60006/upnp/desc/aios_device/aios_device.xml
