Hello, need help here as I tried and it can’t play when set as MQA renderer or as decoder. I have the latest firmware/version for Bothe Audirvana and on the iDSD pro, native DSD over PCM 1.0.
Many thanks,
William
Many thanks,
William
Hello @Antoine, thank you for reaching out. It just freezes and no respond at all. I just need to restart my Mac, and even the iDSD pro and set to non-MQA and then it can play.
Can you try to deactivate the auto-detection of MQA in Audirvana and set it manually as Renderer or Decoder?
Tried, doesn’t work, and the program and the iDSD Pro both freeze and need to force quit / restart.
Done, sent. Many thanks for reaching out and looking into this.
Audirvana Mac Version 3.5.39 (3569)
macOS 10.15.6 with 16384MB RAM
Registered to William Wong
Per track: OFF
No plugin active
Phase = 85
AUTO: /Volumes/music/
Library database path: /Users/apple/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: iFi_Hi-Res_Audio_E188 Model UID:wiimu iFi_Hi-Res_Audio_E188 UID:uuid:FF310036-10FB-AFCA-A2D5-9C5DFF310036
UPnP device at http://192.168.1.21:49152/description.xml
ID 0x0 iFi_Hi-Res_Audio_E188 Manufacturer:wiimu
Volume control: No
http-get::audio/wav:DLNA.ORG_PN=LPCM
http-get::audio/x-wav:DLNA.ORG_PN=LPCM
http-get::audio/mpeg:DLNA.ORG_PN=MP2_MPS
http-get::audio/mp3:
http-get::audio/wma:
http-get::audio/m4a:DLNA.ORG_PN=AAC_ISO
http-get::audio/aac:DLNA.ORG_PN=AAC_ISO
http-get::audio/ac3:DLNA.ORG_PN=AC3
http-get::audio/ogg:*
http-get::audio/ape:
http-get::audio/x-ape:
http-get::audio/flac:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
20 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz
0 physical formats
NrTracks: 0
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData TrackSource out TrackSource PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Next InstanceID in A_ARG_TYPE_InstanceID Pause InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Previous InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData Stop InstanceID in A_ARG_TYPE_InstanceID GetPlayType InstanceID in A_ARG_TYPE_InstanceID PlayType out PlayType GetInfoEx InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition LoopMode out LoopMode CurrentVolume out CurrentVolume CurrentChannel out CurrentVolume SlaveList out SlaveList PlayMedium out PlaybackStorageMedium TrackSource out TrackSource InternetAccess out InternetAccess VerUpdateFlag out VerUpdateFlag VerUpdateStatus out VerUpdateStatus BatteryFlag out BatteryFlag BatteryPercent out BatteryPercent AlarmFlag out AlarmFlag TimeStamp out TimeStamp SubNum out SubNum SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode TransportStatus string OK ERROR_OCCURRED CurrentTrackMetaData string RelativeCounterPosition i4 A_ARG_TYPE_InstanceID ui4 A_ARG_TYPE_SeekTarget string PlaybackStorageMedium string UNKNOWN CD-DA DVD-VIDEO HDD NETWORK NONE RelativeTimePosition string PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL REPEAT_TRACK REPEAT_ALL NORMAL TransportPlaySpeed string 1 PossiblePlaybackStorageMedia string UNKNOWN CD-DA DVD-VIDEO HDD NETWORK NONE AbsoluteTimePosition string CurrentTrack ui4 0 65535 1 CurrentTrackURI string CurrentTransportActions string NumberOfTracks ui4 0 65535 AVTransportURI string AbsoluteCounterPosition i4 CurrentRecordQualityMode string NOT_IMPLEMENTED CurrentMediaDuration string A_ARG_TYPE_SeekMode string REL_TIME TRACK_NR AVTransportURIMetaData string RecordStorageMedium string NOT_IMPLEMENTED RecordMediumWriteStatus string NOT_IMPLEMENTED LastChange string CurrentTrackDuration string TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING NO_MEDIA_PRESENT PossibleRecordQualityModes string NOT_IMPLEMENTED TransportRemote string PlayType string NextAVTransportURI string NextAVTransportURIMetaData string TrackSource string SlaveList string CurrentVolume ui4 LoopMode ui4 InternetAccess ui4 VerUpdateFlag ui4 VerUpdateStatus ui4 BatteryFlag ui4 BatteryPercent ui4 AlarmFlag ui4 TimeStamp ui4 SubNum ui4Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 iFi_Hi-Res_Audio_E188 wiimu http://www.wiimu.com/ WiiMu LinkPlayer WiiMu LinkPlayer http://www.muzohifi.com/ uuid:FF310036-10FB-AFCA-A2D5-9C5DFF310036 V01-Mar 14 2017 00001 iFi_Hi-Res_Audio_E188 FF31003610FBAFCAA2D59C5D QPlay:2 image/png 48 48 24 /upnp/grender-48x48.png image/png 120 120 24 /upnp/grender-120x120.png image/jpeg 48 48 24 /upnp/grender-48x48.jpg image/jpeg 120 120 24 /upnp/grender-120x120.jpg urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/rendertransportSCPD.xml /upnp/control/rendertransport1 /upnp/event/rendertransport1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/renderconnmgrSCPD.xml /upnp/control/renderconnmgr1 /upnp/event/renderconnmgr1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/rendercontrolSCPD.xml /upnp/control/rendercontrol1 /upnp/event/rendercontrol1 urn:schemas-wiimu-com:service:PlayQueue:1 urn:wiimu-com:serviceId:PlayQueue /upnp/PlayQueueSCPD.xml /upnp/control/PlayQueue1 /upnp/event/PlayQueue1 urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /upnp/QPlaySCPD.xml /upnp/control/QPlay1 /upnp/event/QPlay1UPnP devices found : 2
Device #0: ID 0x0 iFi_Hi-Res_Audio_E188 UID: uuid:FF310036-10FB-AFCA-A2D5-9C5DFF310036 Location: http://192.168.1.21:49152/description.xml
Device #1: ID 0x0 Archt One 045B9E UID: uuid:5f9ec1b3-ed59-1900-4530-cc9093045b9e Location: http://192.168.1.2:8080/description.xml
Max. memory for audio buffers: 15226MB
Local devices found : 3
Device #0: ID 0x56 S34J55x Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:0:{2D4C-0F72-43575433}
Device #1: ID 0x4d Rasteme TRU22E USB HD Audio Out Manufacturer: Rasteme Model UID: Rasteme TRU22E USB HD Audio:17D9:0037 UID: AppleUSBAudioEngine:Rasteme :Rasteme TRU22E USB HD Audio:0000:1
Device #2: ID 0x47 Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Can you check if you have some crash report from Audirvana in your Console App of MacOS? You can find it in the crash report section. If you have a recent one when you wanted to play with your iDSD in UPnP, feel free to send it at support@audirvana.com
Thank, Damien, I have sent yesterday.
