iFi iDAC2: does it 'play with audirvana'
Currently using AO (for my own files) and 3.5 (for Qobuz) with my iDAC2…works great. Not sure what ‘plays with Audirvana’ means. Maybe someone could explain that. But, looking at the supported iFi models for my iFi iDAC2, this model is not included in ‘Plays with Audirvana’. Should I care?
No…
A simple axiom: “If it isn’t broken… don’t try to fix it…”
HI @rafs , it’s because I do not have all the information from Ifi to add it to the list but will definitively do so. Can you post your debug info when you have your device connected to Audirvāna?
Audirvana Origin 2.3.4 (20304)
Windows 10 (19045) with 16GB physical RAM
Connected account of :
	Per track: OFF
r8brain with Power Of Two upsampling
Sync list: 2 folders
AUTO: Q:\Music
AUTO: R:\Music
Library database path: C:\Users\User\AppData\Local\Packages\Audirvana.Audirvana-d488-4ebf-b1c4-596e08349a6a_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Q:\Music
Deep Synch: yes
Scanning 145499/186598: Q:\Music\Saffire-The Uppity Blues Women - Saffire-The Uppity Blues Women (2009)
Folders queued for synchronization:
R:\Music\Curley Bridges - Mr. Rock ‘N’ Soul (2001 CD Rip)
Deep Synch: no
R:\Music\Monster Mike Welch - Nothing But Time FLAC
Deep Synch: no
Listening on fd00:6477:7daa:e361:65e1:2c9e:ca7d:cb3c on port 63623
Max. memory for audio buffers: 15172MB
Local Audio Engine: WASAPI
Speakers (iFi (by AMR) HD+ USB Audio)
Model UID:TUSBAUDIO_ENUM\VID_20B1&PID_3008&KS
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{fd3e1f30-e4bf-4167-b342-8c42b0a2aacf}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Selected device:Speakers (iFi (by AMR) HD+ USB Audio)
Manufacturer: AMR
Model name: iFi (by AMR) HD USB Audio
Model UID: TUSBAUDIO_ENUM\VID_20B1&PID_3008&KS
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{fd3e1f30-e4bf-4167-b342-8c42b0a2aacf}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x20b1
USB Product ID: 0x3008
Simple stereo device: No
Local devices found : 3
Device #0: Speakers (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0897&SUBSYS_104387FB&REV_1004
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{0fa9d09c-37d5-4f97-b4a3-8bfd72babfd5}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (iFi (by AMR) HD+ USB Audio)
Manufacturer: AMR
Device #2: Realtek Digital Output (Realtek(R) Audio)
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{153f2dd6-31b7-4d90-b848-ef77601dc919}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #0: OFFICE-DESKTOP-2021
UID: uuid:6143b510-15ca-48aa-b3d1-176fb8716832
Location: http://10.9.18.25:52101/DeviceDescription.xml
Manufacturer: JRiver, Inc.
Model name: Media Center
Hi @rafs,
thanks for the information, will see with iFi about this device.
