Hello!
Playing with Audirvana DSD files, the LED lights correctly:
Blue for DSD64
Magenta for DSD128 and DSD256
But playing PCM files, the LED is always white, indicating 384kHz (the maximum rate the DAC is capable for)
I use:
DAC: iFi Micro iDAC2
MacBook Pro 16 with Big Sur (but the same with an older Mac with Catalina)
I have tried different files, from CD 44.1kHz/16bit to 192kHz/24bit.
The debug info shows correctly:
Active Sample Rate: 88.2kHz
Active Sample Rate: 96kHz
Active Sample Rate: 192kHz
but the LED is always white and NOT
Green for 44/48kHz
Yellow for 88/96kHz
Cyan for 176/192kHz
Upsampling is DEACTIVATED.
If I force the upsamping to DSD64 or 128, the LED color became blue or magenta correctly.
For every other PCM audio file, is always white.
Does this mean that every PCM file is always upsampled to the maximum working frequency of the DAC?
What’s wrong?
Also, plying a CD flac file 16/44.1, Audirvana shows in the bottom right corner of the windows indicates 32/44.1
Does this mean that the 16 bits are sent at the maximum resolution the DAC is capable of?
(The same for the 24bit audio files.)
I think this won’t affect the audio quality, as the “number” contained in a two bytes sequence can be stored correctly in a 4 byte sequence (the 16 or 24 bit sequence will stay perfectly in a 32 bit space).
The main question however is: I would like to know how to let the DAC decode the PCM files at their native rate without upsampling.
Thank you so much for your support!
Mauro
Debug info:
macOS 10.16.0 with 32768MB RAM
Registered to Mauro Bricca
Per track: OFF
AUTO: /Volumes/Archivio/Musica
iTunes/Music library synchronization: last synchronized on Mon Nov 16 22:28:25 2020
Library database path: /Volumes/Archivio/Musica/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1102MB
iFi (by AMR) HD USB Audio Output
UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
ID 0x2c iFi (by AMR) HD USB Audio Output Manufacturer:iFi (by AMR)
Model UID:iFi (by AMR) HD USB Audio:20B1:3008 UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
MQA Renderer device
Stream ID 0x2d 2 channels starting at 1
16 virtual formats:
16 physical formats
Device #0: ID 0x2c iFi (by AMR) HD USB Audio Output Manufacturer: iFi (by AMR) Model UID: iFi (by AMR) HD USB Audio:20B1:3008 UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
Device #1: ID 0x4f Altoparlanti MacBook Pro Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
UPnP devices found : 1
Device #0: ID 0x0 [LG] webOS TV SK8500PLA UID: uuid:67b5b83f-5c88-6c64-4954-67a2b35271be Location: http://192.168.178.66:1372/
