Hi,
After switching to Audirvana 3 my wifi nano idvd is not recognized as did capable but it is. I’m on a mac, 10.14.6, vastest version on Audirvana
That should be ifi idsd.
Fixed - found thread where is says to delete a bunch of old A+ files -
If any one else needs it, here it is
Go to the main library folder… PrivilegedHelperTools folder… Trash the com.audirvana.Audirvana-Plus file
Go to the main library folder…LaunchDaemons folder… Trash the com.audirvana.Audirvana-Plus.plist
Go to User… home Folder… library… Applications Support… Audirvana folder…Trash the AudirvanaPlusDatabase.sqlite (that is your database of music, back it up!)
Go to User… home folder… library… Preferences… trash com.audirvana.Audirvana-Plus.plist (those are A+ software preferences)
