UPNP:
Detection:
PCM supported sample rate : 44.1 - 48 - 88,2 - 96 - 176,4 - 192 - 352,8 - 384 - 705,6 - 768
DSD supported sample rate : 64 - 128 - 256 - 512
DSD Over PCM setting : DoP 1.0
MQA capability : Decoder
Volume:
Volume can be changed : No
Device can mute - unmute: No
Playback:
Best upsampling setting for device :
Setting do not send RAW PCM activated : No
Playback Control:
Gapless playbak option enabled : No
Note: you need to but the Mixer Type for the Volume Options to None to play DSD 512 tracks, otherwise you will be limited to DSD 128.
In the Neo Stream settings page (which can be accessed via the unitās IP address), the default audio buffering setting is 30 mb. To prevent interruptions during playback of DSD 512, please lower the buffering setting to 8 mb.
