Hello,
I am testing out the trial version on Windows 10. I have a Ifi Zen DAC connected to the system and things seem to be working ok except I am not able to control the volume in the Audirvana App. The volume is enabled and moving it up or down or mute has no effect. I can only control the volume via the Zen DAC volume control knob and not via Windows Sound mixer either. Below is the debug: thanks
Audirvana 3.5.43
Replay Gain: by album
SW volume control: ON
Sync list: 0 folders
Library database path: C:\Users\paulmez\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 3546MB
Local Audio Engine:WASAPI
Speakers (iFi (by AMR) HD USB Audio)
Model UID:Speakers (iFi (by AMR) HD USB Audio)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{96c57609-8640-423d-a39d-474a540dfd33}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 32bits Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Speakers (iFi (by AMR) HD USB Audio) Manufacturer:
Model UID:Speakers (iFi (by AMR) HD USB Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{96c57609-8640-423d-a39d-474a540dfd33}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
MQA Renderer device
Simple stereo device: No
Local devices found : 4
Device #0: Speakers (Realtek High Definition Audio(SST)) Manufacturer: Model UID: Speakers (Realtek High Definition Audio(SST)) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{a2688ef0-03c4-4ed1-83e3-dcfa3f97c737}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Headset (Sennheiser MB Pro 2 Hands-Free AG Audio) Manufacturer: Model UID: Headset (Sennheiser MB Pro 2 Hands-Free AG Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{e45479d1-8f23-4c9b-a484-44c05ffbf53c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Telephone (Plantronics P540-M) Manufacturer: Model UID: Telephone (Plantronics P540-M) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{2462a83f-2d07-4410-9b0e-fe9d46abe3fe}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #3: Speakers (iFi (by AMR) HD USB Audio) Manufacturer: Model UID: Speakers (iFi (by AMR) HD USB Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{96c57609-8640-423d-a39d-474a540dfd33}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #0Denon AVR-X3300W UID: uuid:5f9ec1b3-ff59-19bb-8530-0005cda453a6 Location: http://192.168.7.236:8080/description.xml
