Should the zen stream be listed @Antoine ?
Hi @OffRode,
We are currently working with iFi to tackle an issue with the device to be PWA certified. I talked about it with them at Munich and I hope it will be good soon.
Good deal, they have Audirvana on their literature already and mine works well currently.
Great job guys, thanks to the team ![]()
I have Audirvana V 2.3.2 and it is currently recognising my iFi Zen Stream via UPnP as an iFi Neo Stream streaming device. It works but…there are certain obvious differences between the two streamers, for sure, but does it make any real difference for streaming purposes on my LAN. I suppose it does allow me to adjust the (Zen Stream & Zen DAC V1 attached) settings manually but when will Audirvana recognise my streamer correctly with its recommended settings as an iFi Zen Stream with latest firmware version 2.31.7.
Hi @stupendousredman,
It’s possible due to the UPnP naming they have done on their devices. Until the Zen stream is not added, it will be recognized as Neo Stream. and you won’t have the possibility to select the Zen stream.
I have the same issue, but it works fine nonetheless.
I have same issued when after update to origin 2.3.4. It seems work every thing fine but software volume control is disable. It is no longer possible to make it function as previous version. The DAC is Audioquest Dragonfly Red which plug in the USB port behind IFI ZEN streamer directly.
Hello
Same issue as above.
My playback is at times a little buggy specially if I change the output (switching between USB and SPDIF). Will not playback, or play back without sound and need to stop and play multiple times until it works. Sometimes stops working mid song. I also get an error on Adirvana app and need to close and open it (iOS).
Using it with Mac mini OS 10.15.7, Oppo HA-1 (SPDIF) and Chord Mojo 1 (USB).
It sounds great when it works and been working flawlessly for the past hour as I am typing this. Go figure.
What is the error you get?
Hello Antoine
I will send a screen shot if it happens again. I think it says requesting error.
Also Audirvāna is very slow loading and playing the first song compared to my old streamer, microrendu. After first song the speed is ok if changing tracks.
