Hello, my apologies if this is not the place to ask this question. I am now getting the “unable to open an audio file for playback” message when I try to play my files from an external drive. Tidal works fine. The following is the debug info. Any help would be greatly appreciated. Thank you.
macOS 11.2.2 with 32768MB RAM
Registered to [REDACTED]
AUTO: /Volumes/Jukebox/Music
Library database path: /Users/[REDACTED]/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
JDS Labs Element II
Model UID:JDS Labs Element II:20B1:30DA
UID:AppleUSBAudioEngine:JDS Labs:JDS Labs Element II:14600000:1
ID 0x5d JDS Labs Element II Manufacturer:JDS Labs
Model UID:JDS Labs Element II:20B1:30DA UID:AppleUSBAudioEngine:JDS Labs:JDS Labs Element II:14600000:1
Stream ID 0x5e 2 channels starting at 1
16 virtual formats:
16 physical formats
Local devices found : 4
Device #0: ID 0x66 BenQ PD3200U Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:0:{D109-8025-00005445}
Device #1: ID 0x3f CalDigit Thunderbolt 3 Audio Manufacturer: CalDigit, Inc. Model UID: CalDigit Thunderbolt 3 Audio:2188:6533 UID: AppleUSBAudioEngine:CalDigit, Inc.:CalDigit Thunderbolt 3 Audio:3200000:1
Device #2: ID 0x5d JDS Labs Element II Manufacturer: JDS Labs Model UID: JDS Labs Element II:20B1:30DA UID: AppleUSBAudioEngine:JDS Labs:JDS Labs Element II:14600000:1
Device #3: ID 0x4e Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
