Bonjour,
Depuis l’application iOS ou le Mac, impossible d’avancer dans une piste en cliquant sur la barre de défilement;
Merci d’avance de votre aide
macOS 10.15.7 with 4096MB RAM
Licence enregistrée pour Nicolas Poncet
SW volume control: ON
Sync list: 0 folders
Library database path: /Users/nicolas/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: D-Stream Model UID:D-Stream D-Stream UID:uuid:13b23214-00a0-101b-8000-3052cb2b61e8
Currently playing to UPnP device at 32 bits 48kHz
UPnP device at http://192.168.1.39:2870/dmr.xml
ID 0x0 D-Stream Manufacturer:D-Stream
2 available sample rates up to 48000Hz
Volume control: No
http-get::audio/L16;rate=8000;channels=1:DLNA.ORG_PN=LPCM_low
http-get::audio/L16;rate=8000;channels=2:DLNA.ORG_PN=LPCM_low
http-get::audio/L16;rate=11025;channels=1:DLNA.ORG_PN=LPCM_low
http-get::audio/L16;rate=11025;channels=2:DLNA.ORG_PN=LPCM_low
http-get::audio/L16;rate=12000;channels=1:DLNA.ORG_PN=LPCM_low
http-get::audio/L16;rate=12000;channels=2:DLNA.ORG_PN=LPCM_low
http-get::audio/L16;rate=16000;channels=1:DLNA.ORG_PN=LPCM_low
http-get::audio/L16;rate=16000;channels=2:DLNA.ORG_PN=LPCM_low
http-get::audio/L16;rate=22050;channels=1:DLNA.ORG_PN=LPCM_low
http-get::audio/L16;rate=22050;channels=2:DLNA.ORG_PN=LPCM_low
http-get::audio/L16;rate=24000;channels=1:DLNA.ORG_PN=LPCM_low
http-get::audio/L16;rate=24000;channels=2:DLNA.ORG_PN=LPCM_low
http-get::audio/L16;rate=32000;channels=1:DLNA.ORG_PN=LPCM_low
http-get::audio/L16;rate=32000;channels=2:DLNA.ORG_PN=LPCM_low
http-get::audio/mp4:*
http-get::audio/mpeg3:
http-get::audio/mp3:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/aac:
http-get::audio/alac:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/x-m4a:
DLNA 1.5: Yes
Gapless playback: No
Missing events workaround: No
Can play native DSD: No
6 virtual formats:
0 physical formats
CurrentSpeed: 1/1
NrTracks: 1
MediaDuration: 0:03:50.000
CurrentURI: http://192.168.1.17:49152/audirvana/audio_1_37.wav
CurrentURIMetadata:
dc:titleJuniper</dc:title>
dc:creatorLinda Fredriksson</dc:creator>
upnp:artistLinda Fredriksson</upnp:artist>
upnp:genreJazz</upnp:genre>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/kc/kk/gjz8w449fkkkc_600.jpg</upnp:albumArtURI>
upnp:albumJuniper</upnp:album>
nextURI: NOT_IMPLEMENTED
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string NONE NETWORK RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL TransportPlaySpeed string 1 X_DLNA_RelativeBytePosition string X_DLNA_AbsoluteBytePosition string X_DLNA_CurrentTrackSize string RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 65535 CurrentTrack ui4 0 65535 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 LastChange string A_ARG_TYPE_SeekMode string TRACK_NR A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 CurrentTransportActions string SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID X_DLNA_GetBytePositionInfo InstanceID in A_ARG_TYPE_InstanceID TrackSize out X_DLNA_CurrentTrackSize RelByte out X_DLNA_RelativeBytePosition AbsByte out X_DLNA_AbsoluteBytePositionCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 D-Stream D-Stream http://www.d-streamaudio.com AllPlay HiFi wireless adapter WR100-D CUS227 1.0 http://www.d-streamaudio.com/products/wr100-d.html uuid:13b23214-00a0-101b-8000-3052cb2b61e8 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /dmr_rcs.xml /RenderingControl/control /RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /dmr_cms.xml /ConnectionManager/control /ConnectionManager/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /dmr_avts.xml /AVTransport/control /AVTransport/event image/jpeg 48 48 24 /icon/DMR-small.jpg image/jpeg 120 120 24 /icon/DMR-large.jpg image/png 48 48 24 /icon/DMR-small.png image/png 120 120 24 /icon/DMR-large.pngUPnP devices found : 3
Device #0: ID 0x0 D-Stream UID: uuid:13b23214-00a0-101b-8000-3052cb2b61e8 Location: http://192.168.1.39:2870/dmr.xml
Device #1: ID 0x0 Décodeur TV UHD UID: uuid:00ababad-7947-1048-8a00-6cbab81f9f6e Location: http://192.168.1.25:42300/description.xml
Device #2: ID 0x0 Décodeur TV UHD UID: uuid:00ababad-7947-1048-8a00-209a7dc5891a Location: http://192.168.1.18:42300/description.xml
Max. memory for audio buffers: 3072MB
Device #0: ID 0x30 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:86 UID: AppleHDAEngineOutput:1B,0,1,1:0
