Je suis en phase test avec Audirvāna et TIDAL. J’utilise Windows 10 et un dacmagic Cambridge azur. Je réceptionne bien des fichiers en 192 mais la lecture sur dac ne dépasse pas le 48. Auriez vous une solution. J’ai bien sûr essayé de charger le pilote Cambridge mais sans succès. Help me…
Welcome…
Please paste your debug information here so folks can help the best possible you can find it by following these directions:
It appears your DAC supports up to PCM 96kHz file input and subsequently upsamples 96kHz sample-rate and lower sample-rate files to 192kHz… so the DAC is probably decimating the 192kHz files.
Audirvana Studio 2.10.2 (21002)
Windows 10 (19045) x86_64 with 4GB physical RAM
Connected account of : Briou Sébastien
Available network interfaces:
Livebox-doro-seb_5GHz ({5dd26cc3-7377-4d06-b380-f6cd56f6c47c}) is PUBLIC
Active profile types: all
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Sync list: 0 folders
Sync folders at startup: YES
Sort and display order: fr
Library database path: C:\Users\briou\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 177
Listening on 2a01:cb0c:4a4:b800:8108:7c20:f956:e83e on port 59399
TIDAL: Connected as PREMIUM
Font size: regular
Language: Langue du système
Ma Musique
Radios
Podcasts
Streaming
Startup view: Ma Musique : Albums
Number of paired remotes: 1
Screen saver disabled: yes
Max. memory for audio buffers: 2050MB
Haut-parleurs (C-Media USB Headphone Set )
Model UID:USB\VID_0D8C&PID_000C&REV_0100&MI_00
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{906fda32-309e-4e84-aee9-6ca9eab11853}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Selected device:Haut-parleurs (C-Media USB Headphone Set )
Manufacturer: (USB Audio générique)
Model name: C-Media USB Headphone Set
Model UID: USB\VID_0D8C&PID_000C&REV_0100&MI_00
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{906fda32-309e-4e84-aee9-6ca9eab11853}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x0d8c
USB Product ID: 0x000c
Kernel Streaming capable
2 available sample rates up to 48000Hz
Max volume alert: Disabled
Simple stereo device: No
Local devices found : 4
Device #0: Haut-parleurs (Steam Streaming Speakers)
Manufacturer: Valve Corporation Audio DDK
Model UID: ROOT\SteamStreamingSpeakers
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{6530c438-93c3-42bc-b93f-381f7952c258}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Unknown model
Device #1: Haut-parleurs (Steam Streaming Microphone)
Model UID: ROOT\SteamStreamingMicrophone
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{4d405e7c-a98c-4b57-917d-50685529a11b}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Haut-parleurs (C-Media USB Headphone Set )
Device #3: Haut-parleurs (Intel SST Audio Device (WDM))
Manufacturer: Intel Corporation
Model UID: ACPI\VEN_8086&DEV_22A8&SUBSYS_17AA222A
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f97638c4-7cb8-4b39-9e33-a0a7e07ce4b8}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Wi-Fi
UPnP devices found : 2
Device #0: 40DX600_Series
UID: uuid:4D454930-0100-1000-8001-A813749ACA9B
Manufacturer: Panasonic
Model name: Panasonic VIErA
Device #1: Décodeur TV UHD
UID: uuid:00ababad-7947-1048-8a00-d06ededfbcbe
Manufacturer: SoftAtHome
Model name: SoftAtHome Media Renderer
Chromecast devices found : 3
Device #0: les 2 enceintes google
ID: DnsSd#Google-Cast-Group-28F56619D2E045C9819D21CE4D7B4EB2._googlecast._tcp.local#0
Model name: Google Cast Group
Device #1: Google Home
Model name: Google Home Mini
Device #2: Google Nest
Model name: Nest Audio
Here’s your first clue. I’m not sure that I see the Cambridge DAC in play here. Quite a spartan windows box you have there mister.
This appears to be the selected DAC
C-Media USB Headphone Set ) Est bien l’appellation du dac Cambridge connecté. D’après la notice d’utilisation, l’appellation semble conforme au dac.
J’avais potentiellement pensé à un problème de pilotes mais le pilote préconisé par Cambridge de le reconnaît pas…
It’s not showing anything available above 48K, a complete hard reset, ensuring that the firmware is updated. Try swapping USB ports might shake things up for the better? Windows box, do you need a driver installed?
Normalement non, je suis en usb 3 et j’ai testé avec 3 pc windows différents ( Windows 10 et 11) sur plusieurs port usb différents. Je n’ai rien trouvé concernant une éventuelle manipulation sur le dac.
Perhaps as North America awakens we can get some more information.
It certainly seems like something is missing but I’m not familiar with your DAC and I haven’t used windows since retirement. You’ll get it sorted soon.
Best luck with it.
Note the bold text highlighted below:
The headset is the chosen output device and only supports sample-rates up-to 48kHz.
Could you please post a couple of screenshots maybe help him figure out how to get the dacmagic into the game. KISS I would recommend perhaps ![]()
Bonjour @Sebastien_Briou,
si vous essayez de passer de Kernel Streaming à WASAPI, est-ce que le problème est toujours présent?
