I have Windows 10 and I cannot install Audirvana. Apparently I don’t have the application installer program. What would be the indicated program for that?
Thank you
Hello @Dany,
To install and update Audirvana on Windows 10 you need an app called App-Installer, this app is installed by default when you are using Windows 10 1803. If you don’t have it you can install it for free from the Microsoft Store or with this link: https://www.microsoft.com/en-us/p/app-installer/9nblggh4nns1?activetab=pivot:overviewtab
Hola, por favor disculpa la demora en contestar.
Voy a seguir esos pasos para solucionar el problema.
Muchas gracias !!!
