I’ve seen and used a lot of software over the years—certainly in the hundreds—but I must say, Audiravana makes the absolute worst software I have ever dealt with. Once again, I cannot install the ‘non-beta’ software. Just like I couldn’t install the beta software and the update before that, and . . The funny thing is that even if I have the privilege of installing the latest and greatest version, I still face major problems getting this stinking software to work. If only someone with basic experience could buy the company . . . but I am not holding my breath. Maybe at least a few programmers would decide to “test” the software before releasing it. But I understand: this would reveal basic problems, and who has the time?
As an Apple macOS 26.4.1/Audirvāna user, it appears your experience is a corner-case and not typical… If your system is compatible and clean of software that may interfere with the installation and operation, and your license is valid, you should be able join the majority of Apple-centric users like myself that are enjoying Audirvāna.
Hi @RXT1956 , can you please tell me more about what is happening when you try to install the software and then open it?
