I bought Audirvana for Windows 10 but I cannot install it. I get this erros message
Setup has detected that the file ‘C:\Users\USER\AppData\Local\Temp\VSDD6CB.tmp\vcredist_x64\vc_redist.x64.exe’ has changed since it was initially published.
See the setup log file located at ‘C:\Users\USER\AppData\Local\Temp\VSDD6CB.tmp\install.log’ for more information.
Now that the upcoming 3.5 is at a very close to release candidate level, I suggest you install the 3.5 beta instead.
To get it, follow the instructions on the welcome post of the 3.5 beta section of this forum
After downloading and installing the Visual Studio software, return to and download/install your Audirvana.
This worked for me and I’m hoping it will work for you! Let me know.
Hello,
That sucks! I had the same problem! Here is what worked for me:
Google “The latest supported Visual C++ downloads - Microsoft Support”, click the link and scroll down to Visual Studio 2015, 2017 and 2019.
2.Download the appropriate one (for me it was x64: vc_redist.x64.exe
Hello Everybody!
I can’t download the free trial version of Audirvana : Windows 10 tells that the app doesn’t exist ! Is it possible to access directly to the downloaded programm ?
Hello @20cent, before installing Audirvana you’ll need App-Installer, a software made by Microsoft that we use to install and upgrade Audirvana, can you install it and try again?
