Hi, I´m looking at buying Audirvana Origin but first I wish to understand if it is possible, and how to set it up for my needs. Let me explain. I have a PC hooked up to a Devialet amplifier with USB connection. This PC is feeding the music to the amplifier. The music is situated on a harddrive hooked to another PC. Both PCs are connected via network. (I am using PLEX at the moment).
Is it possible to use the PC connected to the amplifier for browsing and to access the music from the second PC? How do I set this up?
Is it possible to access the music from other sources, like laptops in other rooms?
Is it possible to access the music remotely from another house or place?
Is it possible to use a laptop as remote and not a mobile?
This is how I am used to accessing my music although probably not with as high quality.
Thank you for your answers.
Best regards
Andi
