Dear sirs, in Audirvana+ my Arcam Rdac was playing in Integer mode and sound was perfect, after installing Audirvana 3.5 integer mode doesn’t apply when playing and sounds simple. I tried all options but integer mode doesn’t appear in playing file status - what is a difference between plus and 3.5 versions?
Hello @D1000,
Audirvana Mac Version 3.5.29 (3559)
macOS 10.15.7 with 8192MB RAM
Trial version
AUTO: /Volumes/music/
Library database path: /Users/sitec/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4902MB
ARCAM DAC
Model UID:ARCAM DAC:0C56:0002
UID:AppleUSBAudioEngine:ARCAM:ARCAM DAC:14100000:1
ID 0x29 ARCAM DAC Manufacturer:ARCAM
Model UID:ARCAM DAC:0C56:0002 UID:AppleUSBAudioEngine:ARCAM:ARCAM DAC:14100000:1
5 available sample rates up to 96000Hz
32000
10 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 32kHz
10 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 32kHz
Device #0: ID 0x31 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:6 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x29 ARCAM DAC Manufacturer: ARCAM Model UID: ARCAM DAC:0C56:0002 UID: AppleUSBAudioEngine:ARCAM:ARCAM DAC:14100000:1
Integer mode is enabled in your settings, do you have an error when you try to play a track to your Arcam?
No error, but integer mode indicator doesn’t show up near sysoptimizer indicator, and sound is simple compared to plus
You don’t have this at the right bottom corner of Audirvana?
Okay so the Int you see indicate that you are in Integer mode
It doesnt need to be coloured green?
In plus version it is indicated green
In 3.5 it’s indicated when it’s enabled and not indicated when it’s disabled
