macOS 11.2.3 with 16384MB RAM
Per track: OFF
SW volume control: ON
Sync list: 0 folders
Library database path: /Users/andrearossi/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 13468MB
USB High Speed Audio
Model UID:USB High Speed Audio:154E:1003
UID:AppleUSBAudioEngine:D & M Holdings Inc.:DA-300USB:14300000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 48kHz
Active Sample Rate: 48kHz
Hog Mode is on
ID 0x40 USB High Speed Audio Manufacturer:D & M Holdings Inc.
Model UID:USB High Speed Audio:154E:1003 UID:AppleUSBAudioEngine:D & M Holdings Inc.:DA-300USB:14300000:1
8 available sample rates up to 352800Hz
32000
Stream ID 0x41 2 channels starting at 1
24 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
32 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
Device #0: ID 0x31 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:130 UID: AppleHDAEngineOutput:1F,3,0,1,2:0
Device #1: ID 0x40 USB High Speed Audio Manufacturer: D & M Holdings Inc. Model UID: USB High Speed Audio:154E:1003 UID: AppleUSBAudioEngine:D & M Holdings Inc.:DA-300USB:14300000:1
