Integer mode on Fiio BTR13
Hello,
When using Fiio BTR13 on a MacBook Air M2 with integer Mode ON, playback is 44 or 96 but… 16 bits instead of 24.
If I turn integer mode OFF, playback is then 24 bits.
→ is there any solution to this ?
Hi @bnyssen,
Can you send us a copy of the "Debug Infoā€œ when you have this issue? You can get it in Audirvana Settings>My account.
