I noticed that integer mode is not on. Please let me know how to turn it on.
Hello @Sethuraman_Padmesh,
Can you send us a copy of the “Debug Info” when you have this issue? You can get it in Audirvana Settings>General>Debug Info
macOS 11.6.0 with 8192MB RAM
Registered to S PADMESH
No plugin active
Sync list: 0 folders
Library database path: /Users/padmesh/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Helm MQA
Model UID:Helm MQA:2454:129B
UID:AppleUSBAudioEngine:Helm Audio:Helm MQA:20191209:1
Device: 2ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 8 bytes per frame 88.2kHz
Active Sample Rate: 88.2kHz
Hog Mode is on
ID 0x32 Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:123 UID:AppleHDAEngineOutput:1B,0,1,1:0
7 available sample rates up to 192000Hz
32000
Stream ID 0x33 2 channels starting at 1
7 virtual formats:
21 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
2 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 192kHz
2 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 176.4kHz
2 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 32kHz
Device #0: ID 0x32 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:123 UID: AppleHDAEngineOutput:1B,0,1,1:0
Based on the info you sent, I can see Integer mode is on, where do you see it’s not on?
I assumed it will appear as “Int” near SysOpt
Thanks for your quick response
