Bonjour,
voici le debug info
Audirvana 3.5.10
AUTO: C:\Users\O2den\Music
Library database path: C:\Users\O2den\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
TIDAL: Connected as FREE
Max. memory for audio buffers: 1572MB
Local Audio Engine:WASAPI
Speakers (Realtek High Definition Audio)
Model UID:Speakers (Realtek High Definition Audio)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{be48b9da-32aa-4d97-aee4-b1f2c7d4ce37}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 192kHz
Speakers (Realtek High Definition Audio) Manufacturer:
Model UID:Speakers (Realtek High Definition Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{be48b9da-32aa-4d97-aee4-b1f2c7d4ce37}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
4 available sample rates up to 192000Hz
Simple stereo device: No
Device #0: Speakers (Realtek High Definition Audio) Manufacturer: Model UID: Speakers (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{be48b9da-32aa-4d97-aee4-b1f2c7d4ce37}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #0[TV] UID: uuid:0f7f4900-0004-1000-a7f5-1c5a3e7ba3fa Location: http://192.168.1.28:7676/smp_18_
