Bonjour!
I have downloaded the Audirvana demo and so far it’s good except I am downloading the SoniEQ and I can not get it to launch or show up. Do I need to buy the full version to integrate the EQ? I have other VST3 EQ already installed on my Mac.Any ideas?
It’s not showing up with the Activate VST 3 Audio Processing.
I am on Mac OS Catilina v. 10.15.4
I have a DAW installed also, Ableton and Logic Pro X
I also want to ask how is the Codec for music playback higher fidelity than a normal player like I-tunes?
Kind regards
JW
