AU plugin #0: Music Effect - MeldaProduction MEqualizer ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
I’m relying on the members of this group to save me from myself: I’m trying not to fall down the equalizer rabbit hole. I’ve boosted the bass and I’m happy with the result. But I can’t help feeling there’s a better result out there. As Paul Simon says:
The thought that life could be better
Is woven indelibly
Into our hearts and our brains
Here’s what I would like to know: if I set Exclusive Access on my DAC to off, can I mess with the equalizer settings while music is playing and hear instant results?
It is not about ‘Exclusive access’ but about Real-time. This is just below the plug-in setting. Real-time is not possible with DSD or UPnP. Realtime must be enabled and then the plug-in will open when starting a track.
Then you shouldn’t just try 1 plug-in. Multiple brands and types. And don’t forget the effects of resampling after using the EQ. Placing the speakers in the room in relation to the walls also makes a big difference. And the cabling and……… Very happy holidays. Enjoy the music.
I want to thank everyone who pushed me towards the endless experimentation rabbit hole. I’m sorry to let you down, but I have to admit that I am now happy with the sound I’ve got. Here’s what I ended up doing in MEqualizer. The bass has more presence, which is what I was looking for, but doesn’t sound boomy. I paid Melda Production $26 for their plug-in package: satisfied customer and all that. Happy Holidays.
