Hello! I listen to a lot of music that segues directly from one track to another, so gapless playback is a big deal to me. I know the answer is probably no, but is there any way to make Music Integrated Mode run gapless? I’ve spent dozens of hours setting up a bunch of complicated smart playlists and doing very detailed tagging which doesn’t translate well to the Audirvana Studio interface.
More information is needed… Please paste your debug information here:
Creating a debug info
Before you click on the "Debug Info“, please select the correct output.
Once you have done this, go to Audirvana Settings>My account, and you will see the button:
Note: Once you clicked on Debug info,YOU CAN DIRECTLY PASTE IT IN A EMAIL OR TEXT file.
Here’s the debug info:
Audirvana Studio 2.11.2 (21102)
macOS Version 15.6 (Build 24G84) ARM64 with 64GB physical RAM
Connected account of : Thaddeus Milne
Local network access: allowed
LOADING/DECODING:
Max audio buffer size: 10028MB
Internal EQ: OFF
Effect Plugins: ACTIVE in offline mode with plugins using new macOS API
AU plugin #0: Effect - Goodhertz Ghz CanOpener Studio 3 ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
AUTO: /Volumes/Alice/Music/iTunes/iTunes Media/Music
Sync folders at startup: YES
Sort and display order: en_US
Library database path: /Users/tjvm/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Fingerprinting track 18679/26579 : /Volumes/Alice/Music/iTunes/iTunes Media/Music/Peter Maxwell Davies/Solstice Of Light/13 Solstice Of Light (1979) [for Choir, Organ, and Tenor Solo]_ XIII. Invocation Of The Dove.m4a
Listening on
en1 IPv6: 2601:19b:201:90d0:47a:2105:90d4:6d80
en1 IPv4: 10.0.0.208
en1 IPv6: 2601:19b:201:90d0::3a10
on port 54926
Font size: regular
My Music
Radios
Podcasts
Streaming
Use Apple Remote: yes
Number of paired remotes: 0
Screen saver disabled: no
Max. memory for audio buffers: 10028MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Studio 24
Model UID:Studio 24:194F:0108
UID:AppleUSBAudioEngine:PreSonus:Studio 24:ST1E18091888:1,2
Active Sample Rate: 48kHz
Selected device:Studio 24
Manufacturer: PreSonus
Model name: PreSonus Studio 24
Model UID: Studio 24:194F:0108
UID: AppleUSBAudioEngine:PreSonus:Studio 24:ST1E18091888:1,2
USB Vendor ID: 0x194f
USB Product ID: 0x0108
ID 0x3a
Stream ID 0x3b 2 channels starting at 1
12 virtual formats:
12 physical formats
Local devices found : 8
Device #0: ID 0x4d DELL S2721H
Manufacturer: DEL
Model UID: 10ACF541-0000-0000-331F-0103803C2278
Model name: DELL S2721H
Device #1: ID 0x3e LG TV SSCR2
Manufacturer: GSM
Model UID: 1E6D0100-0000-0000-0120-010380A05A78
Model name: GSM LG TV SSCR2
Device #2: ID 0x3a Studio 24
Device #3: ID 0x80 BlackHole 2ch
Manufacturer: Existential Audio Inc.
Model UID: BlackHole2ch_ModelUID
UID: BlackHole2ch_UID
Model name: Existential Audio Inc. BlackHole 2ch
Device #4: ID 0x7a Mac Studio Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Mac Studio Speakers
Device #5: ID 0x90 Screenflick Loopback
Manufacturer: Araelium Group
Model UID: com.araeliumgroup.screenflick.loopback
Model name: Araelium Group Screenflick Loopback
Device #6: ID 0x5c Quicktime Input
Model UID: ~:AMS2_Aggregate:0
Model name: Apple Inc. Quicktime Input
Device #7: ID 0x60 Screen Recording Audio
Model UID: ~:AMS2_StackedOutput:0
Model name: Apple Inc. Screen Recording Audio
Wi-Fi
Do you get gapless if you deactivate the plugin?
That fixes it! Thanks
