Audirvana does not run in Integer Mode as it feeds my Mac Mini’s Dante Virtual Sound Card which outputs via Ethernet to an Atterotech unDaes-O which then outputs over AES/EBU to my Schiit Audio Yggdrasil DAC. Audio Over Internet Protocol (AOIP) sounds better than USB in my system using iTunes, Roon, Pure Music.
It will run in Integer Mode if Audirvana outputs to the Yggdrasil over USB.
Both sound great and similar. But I wonder if AOIP would be even better if Integer Mode was active.
Thanks for the input.
DSNORD
