Hi, thanks for responding,
It’s not a smart list. I had made a Folder a few days ago, and put some playlist titles inside of it that I knew I would populate once I got all my music imported and meta tagged (in an outside application). Once I finished the metatagging process I’d be able to see the attributes of each file easier inside of Audirvana.
So when I came back to Audirvana, opened it up, and got a feel for where all my files were I started to drag and drop individual songs over to those playlists I had made a few days ago.
NO - GO.
Hard Stop.
I dragged them over to the playlists and it would not let me drop them into or onto the playlists. Any of them…
I created new playlists to take the place of the old ones and a couple of times I was successful in dragging and dropping but just when I thought my problems were over with - the ability to drag and drop would stop again. I could no longer drag and drop. It makes no sense to me so that’s why I wrote this question.
I wound up messing around with it quite a bit because I was so frustrated, and I am seeing that so long as I don’t put the playlists under a folder, or inside a folder, I won’t have nearly as many rejections (can’t drag and drop). If I leave the playlists out in the open - messy and uncategorized all sitting out there NOT inside a folder - I can drag and drop.
It’s making a mess of my organization structure, but it looks like I can drag and drop into those new folder-playlists just fine now and I can’t tell you why.
I also just tried to drag and drop into Playlists I had already made prior to a few days ago and, for some reason this morning, it’s all working properly.
I have no idea why I struggled so hard yesterday. I couldn’t drag and drop anything into any of the folders/playlists.
I’m on a MacOS Catalina Version 10.15.3 Brand new Macbook 16" if that helps you out at all.
I love this application, just getting used to using it.
Thanks for your quick response.
YY
