It’s not important because I can sync all my music which is not in ISO format. I am using SMB, of course.
I was asking because I thought it might be related to some limitation, like 2GB file size or something.
No, it’s not. This was working before, I had no issues importing ISO files in my library. Stopped working for a couple of moths ago. Really frustrating. I am pretty certain that my equipment, the network and all the clients are working correctly so this must be somehow related to Audirvana software.
Maybe, maybe not.
If you’re on Catalina, change the max SMB level to SMB3 in the NAS config.
I just added another album in ISO format and the scan recognised it. Have not changed anything, just run the scan after adding the album.
Another thing which is not working as expected or as it’s supposed to do is selection of “Recently added” in the library. What is the actual criteria for selection of albums that will be included in Recently added selection? What that selection should do is to include albums found in the last couple of syncs and sort them by the date added. However it’s working now, it’s applying a logic which I cannot follow. Please explain.
Recently added… just do a right click and edit if not good…
mine is working perfectly… last 30 days showing.
Bonjour,
J’ai un souci de lecture avec les fichiers sacd ISO, quand je sélectionne un album dans ma bibliothèque (un album ISO ) ça met un temps de chargement qui dépasse parfois une a deux minutes avant la lecture, c’est très long .
avant d’acheter audirvana j’avais un autre lecteur gratuit connu des audiophile qui été très réactif ,très rapide pour lire les fichiers ISO sacd extraction et lecture en instantané , y’a t’il d’autres personnes qui on le même problème que moi ?
Merci pour votre aide.
Bonjour Damien ,
Oui tout mes fichiers sont sur un nas Synology, quand je teste avec f2000 j’ai aucun souci ,la lecture démarre en fraction de seconde.
Cordialement
Pouvez-vous m’envoyer une copie de votre “Debug Info” ? Vous le trouverez dans les paramètres d’Audirvana>Général>Debug Info
Remarque: En cliquant sur le bouton Debug Info, Audirvana copie automatiquement tout son contenu, il ne vous reste plus qu’à le coller en réponse de ce message
Ok des que je rentre chez moi je ferai le nécessaire .
Merci a vous.
macOS 11.1.0 with 8192MB RAM
Licence enregistrée pour K MOUSSAOUI
Sync list: 2 folders
AUTO: /Volumes/music/DSD- SACD-DTS
Manual: (OFFLINE) /Volumes/usbshare1/dsd
Library database path: /Users/chaneze/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as
iFi (by AMR) HD USB Audio Output
UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:14200000:1
ID 0x42 iFi (by AMR) HD USB Audio Output Manufacturer:iFi (by AMR)
Model UID:iFi (by AMR) HD USB Audio:20B1:3008 UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:14200000:1
Stream ID 0x43 2 channels starting at 1
16 virtual formats:
16 physical formats
Device #0: ID 0x35 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:126 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x42 iFi (by AMR) HD USB Audio Output Manufacturer: iFi (by AMR) Model UID: iFi (by AMR) HD USB Audio:20B1:3008 UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:14200000:1
