@Damien are you listening? The fixes we are sharing are OTHER PLAYERS.
Audirvana is showing the exact format of the audio data sent to the DAC. Other players may not have this information or be less precise.
And this is not an issue. This is simply that the DAC USB interface is accepting only 24bit (or 32bit) PCM signal. And this is very common.
@alberto1 DAC is such one, as the Debug Info shows there is only 24bit integer streams available, in addition to the 32bit float macOS standard ones. (And 32bit float is actually 24bit integer precision, the other 8bit being for the exponent value).
@aja You’ll want to post a copy of your Debug Info (command in the General section of the preferences page, then Ctrl V in a post). This will tell the exact stream formats your DAC is accepting.
There is the case of some DACs that are made of an off the shelf USB interface that accepts 32bit and 24bit streams, and a DAC chip that does not accept 32bit signal. Audirvana has then a setting to cope with such DAC design issue: in the bridge paragraph in the first section of the audio settings page, select the option to send only 24bit data (and not 32bit).
So help us understand if this 24 bit accepted output by the DAC is still bit perfect or not.
I’m not Damien’s spokesperson, but I interpret this as yes.
Only available for Upnp (then in active device), at least in W10. Audirvana always sends out 32 bit to USB, to both my dacs, IFI NANO iDSD, which is capable, and the Cambridge DAC magic plus, which is 24 bit only. I would like to use the IFI as bridge, but this is not possible. It receives 32 bit, so TOSLINK or S/PDIF out doesn’t work.
BR
BB
On MacOS it’s available over USB. Maybe it’s a bug in the Windows version.
Sure no bug, it’s just that Windows version is behind…
BR
BB
Hi,
I encountered the same issue although with a marantz HDMI receiver( audio output only sending 24/44 whatever the original sample rate being played). Then I realized I had to manually set the option in the general tab for bridge devices to DAC to a higher sample rate (I use 96) to allow upsampling to work or allow higher resolution files like MQA to pass apparently untouched. Not sure what this option does exactly, but it seems to have solved my issue as the output correctly shows 24/96 now. In case this is helpful to someone.
The setting is there, but displayed only if your DAC has both 24 and 32bit streams available.
Checking in the Debug Info taken with your DAC connected and selected will tell you which streams it offers.
Debug info Cambridge DAC magic plus:
Audirvana 3.5.1
Sync list: 0 folders
Library database path: C:
Max. memory for audio buffers: 6862MB
Local Audio Engine:ASIO 2 driver version 1071
CA USBAudio ASIO Driver
Model UID:CA USBAudio ASIO Driver
Device: 2ch 32bits Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Sample rate switching latency: 1s
CA USBAudio ASIO Driver Manufacturer:
Model UID:CA USBAudio ASIO Driver UID:CA USBAudio ASIO Driver
5 available sample rates up to 192000Hz
Device #0: CA USBAudio ASIO Driver Manufacturer: Model UID: CA USBAudio ASIO Driver UID: CA USBAudio ASIO Driver
Device #1: iFi (by AMR) HD USB Audio Manufacturer: Model UID: iFi (by AMR) HD USB Audio UID: iFi (by AMR) HD USB Audio
UPnP devices found : 3
Device #0
Device #1
Device #2
What is the lesson from this? Does it really accept only 32 bit? Why should this be? It’s a 24/192 DAC. To be checked the same way my IFI, to be continued
BR
BB
That’s the point, your DAC offers only 32bit streams.
As you are using ASIO there, you may want to check if in WASAPI, you get the 24bit streams as well.
If yes, then this is an ASIO driver issue.
It offers a lot more, but still there is no option anywhere to define or limit the word length, 24bit, 32bit or similar
BR
BB
Here is the debug info:
Audirvana 3.5.2
Per track: OFF
AUTO: \PEISESTUE\Music\Music flac
Library database path: C:\Users\omath\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 670MB
ASIO MADIface USB
Model UID:ASIO MADIface USB
Active Sample Rate: 48kHz
ASIO MADIface USB Manufacturer:
Model UID:ASIO MADIface USB UID:ASIO MADIface USB
13 available sample rates up to 11289600Hz
2822400
5644800
11289600
DSD capability: Raw DSD (MSB)
Device #0: ASIO MADIface USB Manufacturer: Model UID: ASIO MADIface USB UID: ASIO MADIface USB
Regards
Øyvind
Hello @aja,
I can see in your debug info that you can only have 32 bit capability with your ASIO driver, could you try with WASAPI?
Hi @Antoine,
I’m a bit confused. I have the same issue (each 16bit/44kHz file is sent out as 24bit/44kHz), but my dac is connected via an optical cable (my Rega dac is optimized for toslink, not usb).
Are my Audirvana settings optimal for best sound quality? Many thanks for (anyones) (your) feedback!
Debug info:
Audirvana Mac Version 3.5.30 (3560)
macOS 10.13.6 with 8192MB RAM
Per track: OFF
iZotope SRC not in use iZotope SRC filter parameters
Steepness = 150
Filter max length = 500000
Cut-Off (x Nyquist) = 100%
Anti-aliasing = 200
Phase = 100%
AUTO: /Volumes/HDD1 4 TB/Mark’s Muziekbibliotheek/Music
iTunes/Music library synchronization: last synchronized on Fri Jan 17 07:39:03 2020
Library database path: /Users/***/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Direct Mode audio path, buffer I/O frame size: 4096
Built-in Output
Model UID:AppleHDA:35
UID:AppleHDAEngineOutput:1B,0,1,2:0
Hog Mode is on
ID 0x4f Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:35 UID:AppleHDAEngineOutput:1B,0,1,2:0
5 available sample rates up to 96000Hz
32000
Stream ID 0x50 2 channels starting at 1
5 virtual formats:
20 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
2 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 32kHz
Local devices found : 3
Device #0: ID 0x4f Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:35 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x54 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:35 UID: AppleHDAEngineOutputDP:0,1,0,1,0:0
Device #2: ID 0x29 Hue Sync Manufacturer: Philips Lighting B.V. Model UID: com_lighting_HueSyncEngine:0 UID: com_lighting_HueSyncEngine:0
UPnP devices found : 1
Device #0: ID 0x0 BRAVIA KD-49X8505B UID: uuid:00000000-0000-1010-8000-fcf1528de4bb
Back again…
Nou I’m seeing MQA files being upsampled as well.
See screenshot.
Any help in the right settings is much apreciated.
i don’t stream, my dac is not mqa… but upsampling option are in your dac settings in Audirvana bottom right speaker icon… put it at Deactivated, if already there, must be a mqa thing
It was set to ‘deactivated’ so thats not the problem…
There’s no upsampling going on. The MQA file is just unfolded (1st unfold).
I understand. Thanks for the replies.
So there is no setting I need to change to get more out of my system?
