Debug info below. I think this is not the info you are looking for, because I did shut down my PC yesterday, so I think all relevant information about yesterday’s night session is lost. Let me know if this is useful already, or you need more information (Then I will also power up the Pi4/Moode and listen some songs, after which I will share the debug info).
About editing posts, Im sorry to say, but when I hit the " …" I can ‘share’, ‘bookmark’ and ‘delete’ the post, not edit.
debug info:
Audirvana 3.5.12
AUTO: Z:
Library database path: C:\Users\Alex\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 2292MB
Local Audio Engine:WASAPI
Moode UPNP
Model UID:JF Light Industries Moode UPNP
UID:uuid:2dfea03c-6f8a-b387-b7bd-dca63299c142
Active Sample Rate: 48kHz
Realtek Digital Output (Realtek High Definition Audio) Manufacturer:
Model UID:Realtek Digital Output (Realtek High Definition Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{d7ce07e6-0081-443a-9f4b-270628984a71}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
4 available sample rates up to 192000Hz
Simple stereo device: No
Device #0: Realtek Digital Output (Realtek High Definition Audio) Manufacturer: Model UID: Realtek Digital Output (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{d7ce07e6-0081-443a-9f4b-270628984a71}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: 5 - U28E590 (AMD High Definition Audio Device) Manufacturer: Model UID: 5 - U28E590 (AMD High Definition Audio Device) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{3bd80335-4ab8-47bb-b7eb-332cf2f90116}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
