I don’t know if this is a bug but it is something that i find really annoyng.
I use Audirvana with E30 dac and Asio drivers under windows.
Normally Audirvana works fine in exclusive mode,
but when the sample rate of a track is the same than the default sample rate that i have setup in the windows sound panel it happens that Audirvana works in shared mode and i have the sounds by other applications or games. I hope that this will be fixed in future.
Which sample rate did you set in the control panel?
This happen with any sample rate. I have tested setting 44100 in the control panel and when the track has the same sample rate audirvana is not in exclusive mode.
