Hello,
I have done some further testing.
Summary:
With Chord direct USB connection:
Asio works fine with No upsampling and r8brain x2. Won’t start playing with upsampling to max.
Wasapi works fine with r8brain upsampling and DSD over PCM1.0 up to DSD 256
With SRC-DX: cuts with either no upsampling or any upsampling.
Debug info below.
So I guess for now the issue seems to be related to src-dx, a 250$ product…
Debug info:
Audirvana Studio 2.6.6 (20606)
Windows 11 (22621) with 16GB physical RAM
Connected account of : Jean-Pierre Hennion
Available network interfaces:
Box4g ({9fb80309-ae16-47fc-bf67-f271a9d5077f}) is PUBLIC
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Stop band attenuation 110.816dB
AUTO: C:\Users\jphen\Music
Library database path: C:\Users\jphen\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 467
Listening on 192.168.68.109 on port 54516
Max. memory for audio buffers: 8192MB
Local Audio Engine: WASAPI
Haut-parleurs (SRC-DX)
Model UID:USB\VID_2FC6&PID_6013&REV_0201&MI_00
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{3e3f411c-63d9-45cd-8573-e866580f5f49}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 32bits Integer, 8 bytes per frame 768kHz
Active Sample Rate: 768kHz
Limit bitdepth to 24bit: ON
Selected device:Haut-parleurs (SRC-DX)
Manufacturer: AUDIOWISE
Model name: SRC-DX
Model UID: USB\VID_2FC6&PID_6013&REV_0201&MI_00
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{3e3f411c-63d9-45cd-8573-e866580f5f49}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x2fc6
USB Product ID: 0x6013
Max volume alert: Disabled
DSD via PCM 1.0
Simple stereo device: No
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
2 ch Integer PCM 24bit little endian 705.6kHz
2 ch Integer PCM 24bit little endian 768kHz
Device #0: Speakers (Realtek High Definition Audio(SST))
Manufacturer: Realtek
Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0274&SUBSYS_10EC1284&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{0f652d97-669b-4cc3-8d3b-91de29d44e31}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Intel High Definition Audio
Device #1: Haut-parleurs (SRC-DX)
Model name: SRC-DX
Chromecast devices found : 1
Device #0: MiProjM05
Model name: MiProjM05
