Hi. I am new to the community and to using eq. I installed Toneboosters Equalizer 4, as it was recommended by a friend, but I cannot get it to work properly with Audirvana. The first issue that I encounter is that when I click on the configure button on the VST effects window, it only shows part of the upper left quadrant of the eq screen. The other issue I have is that I am getting clipping, even if I set the eq flat to zero in the Toneboosters app. Can someone please provide me some guidance on how to avoid or fix these issues? Thank you!
Hello @wichiewichie,
We are aware of this issue and we are currently working on a fix for it. The workaround is to enable real time and while you play a track, you will be able to change the plugin settings.
Audirvana Studio 1.10.2 (11002)
Windows 10 (19043) with 16GB physical RAM
Connected account of : Luis Rivera Lopez
VST3 plugin #0: C:\Program Files\Common Files\VST3\ToneBoosters\Equalizer_v4\TB_Equalizer_v4.vst3
ClassID: 5653545434455174625F657175616C69
VST3 plugin #1: None
VST3 plugin #2: None
VST3 plugin #3: None
AUTO: C:\Users\lrivera\Music
Library database path: C:\Users\lrivera\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2601:191:8580:6280:c975:6872:d1a:c623 on port 52199
Max. memory for audio buffers: 5028MB
Local Audio Engine: ASIO ASIO 2 driver version 0
Speakers (Burson Audio XMOS USB)
Model UID:MMDEVAPI\AudioEndpoints
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{b2247a1d-a3fb-455c-9a09-df2110bf428b}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 88.2kHz
BursonAudio USB Audio Device
Manufacturer:
Model Name: BursonAudio USB Audio Device
Model UID: BursonAudio USB Audio Device
2822400
5644800
11289600
22579200
DSD capability: Raw DSD (MSB)
Device #0: BursonAudio USB Audio Device Manufacturer: Model UID: BursonAudio USB Audio Device UID: BursonAudio USB Audio Device Model Name: BursonAudio USB Audio Device
Device #1: iFi (by AMR) HD USB Audio Manufacturer: Model UID: iFi (by AMR) HD USB Audio UID: iFi (by AMR) HD USB Audio Model Name: iFi (by AMR) HD USB Audio
Do you have clipping if you are using WASAPI instead of ASIO?
Just tried it with WASAPI and it clips too.
Can you send a screenshot of your plugin so I can try reproduce the clip with my computer?
The first one is the default set at zero and the second one is the one I was trying to set initially.
I get the clips too but only on the Windows version, not on MacOS
Thanks for the update. At least I know that it is not just me. Is it related to Audirvana or Toneboosters? Can you recommend another eq that doesn’t create this issue with the Windows version of Audirvana? Thank you!
Yes it is but we are working on it. In the meantime, you can try this one ![]()
Thank you!
Quick question - If you’ve paid for the app i UAPP is it valid for this plugin?
