Hi ,
Does anyone knows how to fix transmission problems from Audirvana to my network streamer PRIMARE NP5 ? After every three tracks on Qobuz or NAS, it makes shut down the connection. I have to set up the streamer every time. Original PRIMARE streamer instructions recommends Roon system… What about Audirvana ? Is it fully compatible ? Thank you in advance…
I got the same problem with my Primare NP5. Did you find a solution?
I got a NP5 last week and been having nothing but crashes trying to run it with Audirvana. Even when it works, it keeps skipping tracks, rewinding or fast forwarding for no apparent reason. It’s now not even coming up on Audirvana runnning on my MacBook Pro but comes up on the iMac. Works flawlessly with Roon. In other words, it’s really not fully compatible with Audirvana.
